Hal has just released their new double adjustable shocks along with a few new spring rates for the f-body.
Double Adjustable Front F-Body Shocks
• Ride Height Adjustable Directly threaded body allows for stock or Aluminum shock with 576 valving options. Allows truly independent adjustment of compression and rebound. 24 positions of compression adjustment on one knob, and 24 positions of rebound adjustment on the other knob. Each knob is clearly labeled with an "R" for rebound or a "C" for compression, as well as plus and minus symbols for ease of adjustment.
Front F-Body Springs
QA1 offers the perfect springs for 1993 - 2002 Camaro/Firebird front suspensions using the GEN-F front shock. QA1 now offers three spring choices for your Gen-F vehicle. Purposely built with factory and modified small block cars in mind, the springs below are designed to set on the GEN-F spring seat and fit into the factory location at the top. When used in conjunction with the GEN-F front shocks, they are unmatched in ease of installation and performance.
- 275 lb. spring Drag Racing
- 300 lb. spring Nice Ride & Handling
- 325 lb. spring Firm Ride, Great Handling & Cornering
Double Adjustable Rear F-Body Shock
Aluminum shock with 576 valving options. Allows truly independent adjustment of compression and rebound. Includes Lower shock bolt.
We have a group purchase running for these and all of the other Hal products through May 6th. More info can be seen in the Group Purchase section of our website.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
