over the last several months i have built an engine and been installing it for a friend of mine in his 1992 corvette. it has the ZF 6 speed. i installed a spec stage 5 clutch, pressure plate, and billet flywheel. when you get in the car and step on the clutch pedal, it goes right to the floor, so in went a new slave, and master, and it was blead properly. so i finally turned to my last effort. i tore the tranny out this morning, and looked every thing over. every thing looks correct, the only thing that seems wrong is the distance that the release fork moves on the release bearing, i would say it pivots and moves about .75-1 inch stop to stop. before engauging the bearing(does this make sense?) so i am currious if i put something in wrong, or if i have the wrong bearing? the bearing came with the clutch from spec, and the fork is the original from the car with 42K on it and it looks almost new. HELP lol
NFB, sort of corvette 6 speed clutch ?
past rides:
1994 Z28 A4 totaledTags: None
