Last minute gift ideas!
  • Last minute gift ideas!
    If you have an "Automotive Minded" person in you life,
    these gift suggestions should be considered.
    1. Tire Air Change Kit. This kit comes with everything
    you need to
    change the air in your tires. This highly recommended
    but often
    overlooked maintenance item is much easier now.
    Remember to change
    your air every 3000 miles or twice a year. $25
    2. Blinker Fluid. You knew it existed but, WOW, is
    this stuff hard to
    find. 4oz bottle. $12
    3. Synthetic Blinker Fluid. Better yet! 4oz bottle.
    $24
    4. Light Bulb Filaments. Why throw away a perfectly
    good turn signal
    or stop light bulb when you can just install a new
    filament? Premium
    Filaments, made in the USA! $1 each.
    5. Manifold Heat. Yes, your exhaust manifold should be
    HOT. If it's
    not, you may need this item.
    Sold by the pound. $3.50
    6. Steering Wheel Gaskets. All SIZES available! Email
    for specific
    application. From $9.99
    7. Tie Rod Tensioner. Is your tie rod limp? Tension it
    with T-50!
    $14.99
    8. Alternator Batteries. (4 required, replace them
    all!) >From $2.99
    9. Fan Belt Buckles. Specify brass or chrome. Gold
    available special
    order. $14.99
    10. Muffler Bearing Manual. Print version $59.95
    11. Muffler Bearing Manual. CD version $49.99
    12. Universal Muffler Bearing Tool Kit $105.59
    13. Muffler Bearing Hi Temp Synthetic Lube (the only
    kind we sell!)
    $40.24
    14. Muffler Bearings From $19.95
    15. Muffler Bearing Gasket Kits From $9.99
    16. Momentum (required for tackling some off road
    obstacles). Sold by
    the lb-ft/sec $0.50
    17. Microsoft Windows Eliminator. If your car or truck
    begins to run
    poorly, (long time to start, frequent crashes, etc.),
    it's computer,
    (ecm, ecu, black box, etc.), may have become infected
    with this nasty
    computer virus. This product will safely remove the
    virus. $199
    18. Mirror Image Flipper Film. Did you know that the
    image you see in
    your rear view mirrors are reversed! This is a
    manufacturing flaw
    that the auto companies have kept secret for years as
    the recall
    would cost BILLIONS! This film can be cut and placed
    over any mirror
    to correct the image. Now you'll be able to read signs
    in the rear
    view mirror! $5 per square ft.
    Received from Pastor Tim
    Nice one...I will have to look into some of those...
    Greg W. in West Michigan
    1983 Z28-Parts car- *Sold*
    1984 Z28-305 HO Auto *Sold*
    1986 Camaro-V-6 5Spd *Sold*
    1984 Camaro-V-6 Auto *Sold*
    <Motor out
      I just changed out my blinker fluid.
        Should i let my engine cool before i check for the HEAT on my manifolds? Is it safe to just check on it
        2006 Saturn Ion Redline
        2003 Mits. Eclipse Spyder
          hahaha...I was reading and thinking to myself...WTF?!? That's a good one...
