For the past few months now I've been having trouble with my Jeep. I put a Howell EFI kit on it, which is basically the Chevy pickup EFI right down to the PCM (of course there are some custom parts). A few months ago, as I'm driving home, I notice the SES light come on and its idling pretty bad. Pulled the code...code 33, MAP sensor reading low or no vacuum (or something to that effect). I hooked up my vacuum test guage today (finally got one) and it oscillated between 13 and 14" of vacuum, read down to 8-10" when I revved the motor. But, when I pulled off the line (essentially creating a vacuum leak), the motor started idling much better, almost where it should be idling. Any ideas? Thanks in advance guys.
Problem with my Jeep
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Tags: None
I actually relocated the MAP to the TB at the suggestion of the Howell Techs a couple months ago...still nothing.Originally posted by 88bird5spdtry puttin a new line between the map and the intake and see if that works
The MAP was originally on a vacuum line which connected to a port on the intake manifold, as you pointed out. This port is also where I connected the test gauge directly, not using a T-junction.
I did forget to mention that this all started after I came off the freeway coming home from a buddy's house. Since there's no OD, the motor revs higher down the freeway at ~75.
Could this be an intake manifold leak? Any way to check? Maybe something else?Steve
Mods
Mods
Mods
You can always do the old trick of spraying a small amount of starting fluid around the intake and listen for the motor to rev that found the intake elbow leak on my firebird. Also you may want to ask this on www.jeepforum.com theres some pretty knowledgable guys over there.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Thanks man, I'll give that a shot when I get another chance to pop the hood on Thurs. Also, isn't there a trick with adding ATF into the intake and watching for smoke?Originally posted by 94 formulaYou can always do the old trick of spraying a small amount of starting fluid around the intake and listen for the motor to rev that found the intake elbow leak on my firebird. Also you may want to ask this on www.jeepforum.com theres some pretty knowledgable guys over there.
I did post this on the forums at www.ifsja.org, which also seems to be a pretty good board. I'll give the forum you suggested a try too, thanks.
Steve
Mods
Mods
Mods
The main problem is.... It's a Jeep.
J/K
Seriously... I immediately thought of a vacuum leak. My Bravada had a very similar problem last year. It was idling very rough, almost to the point of stalling. Found a vacuum leak by the firewall (it was a vent hose). I used the soapy water trick on all the hoses to check for it. It's tedious, but it worked.SOLD: 2002 Trans Am WS.6 - Black on Black - 6 Speed
Oh ha ha haOriginally posted by 02 WS6The main problem is.... It's a Jeep.
J/K
Anyways, I'll try the soapy-water or starting fluid trick. I do have a friend who says that the AMC motors are notorious for going through intake manifold gaskets (though I've never experienced that problem...yet). Maybe I'll start there. Any other suggestions? Would the ATF trick work? Thanks guys for your help so far
(except for 02 WS6...I just hate that guy...lol
Steve
Mods
Mods
Mods
what he said... thats way too low.Originally posted by Joe 132013-14 is low at idle. You should be in the 17-18 range. Check for vacuum leaks! go over everything from the brake booster to vent lines..... anything that uses a vacuum source.
I think I'll stick with starter fluid, thanks lol. I'm assuming carb cleaner would work too, yes?Originally posted by Joe 1320Propane. Just don't smoke while you are using it.
I had one of the guys on www.ifsja.org tell me it was because its running rich...isn't that the symptom, not the cause?Steve
Mods
Mods
Mods
Like I don't hear that from my wife every day...Originally posted by Steve93ZThanks guys for your help so far
Well, as long as its not just me saying, then I don't feel so bad lolOriginally posted by 02 WS6Like I don't hear that from my wife every day...
Hey, could it be possible that, for some reason, the timing chain slipped and is causing all this? Or is that something I should check last?Steve
Mods
Mods
Mods
I wouldn't rule anything out, as a rough idle can be caused by a million things... but a vacuum leak is the easiest, and most likely culprit.SOLD: 2002 Trans Am WS.6 - Black on Black - 6 Speed
And I hope its something simple too, like a hose just popped off. I need more complications like I need another hole in my head
Steve
Mods
Mods
Mods
