What do you guys think of using Nitrogen to fill your tires up? Belle Tire is now doing a promo to use nitrogen instead of air...See here
ogenic separation from air. In the process, the water that was in the air stays with the air, and does not end up in the nitrogen fraction. As a result, nitrogen is "dry" and unlike air, does not have any water vapor in it. It is this that accounts for nitrogens lower sensitivity to temperature changes. In high concentrations, water in a cold tire (filled with air) can condense and become a liquid. When the water heats up, it changes phase and vaporizes, occupying singificantly more volume, and inreasing the pressure in the fixed volume more than it would have increased if the air was "dry". Without the water vapor, "dry" nitrogen follows the perfect gas law, and does not increase/decrease pressure at the same rate "wet" air does.
