I have a stupid question...what is the difference between a 400ci big block and a 400ci small block? Also, what makes a big block a big block? Is it the stroke, bore, v angle, or what?
BIG block/small block
1997 Formula WS6
43,000 miles, LT4 Hot Cam, 1.6 Roller Rockers, Ported Heads, Long Tubes, Borg Warner Built T56, Stage 3 Clutch, Aluminum Drive Shaft, Strange Engineering 12 bolt 4.11 Rearend, Nitrous Express wet shot.
2006 Saab 9-3 2.0T
18,000 miles, Stock, and staying that way (Daily Driver).Tags: None
AMC had only 1 block.
Chrysler and Chevy had a small and big block.
Ford had a small block, medium small block, medium block, medium big block and big block. LOL2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Yeah, I'm still not getting it. The physical block size wouldn't that have to do with the stroke too? I'm not trying to be difficult, but I really still don't get it.1997 Formula WS6
2006 Saab 9-3 2.0T
Originally posted by 97formws6Yeah, I'm still not getting it. The physical block size wouldn't that have to do with the stroke too? I'm not trying to be difficult, but I really still don't get it.
You can also have a large box that contains small contents, you could also cram the same contents into a smaller box. of course the best of all is a big box with big contents.
Lots of reading out there for it http://www.google.ca/search?client=f...=Google+Search97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
Most manufacturers build engine groups or families- the small block chevy SBC, was a single casting that could be bored to different cylinder sizes and use differing crankshafts and could be built as a 283, 305, 327, 350 and even a small block 400- externally all the same, used same manifolds, distributors, etc.- the big block was a different casting, and, depending on what piston diameter it was bored for and what crank was used, could be a 396, 427 or 1 454- the transmission bell housings and engine mounts were different for small block/big block-
All bets are off if you go far enough into the past to have Pontiac or Oldsmobile big blocks and small blocks- they tended to be different animals totally.
Chrysler did the same with the 273-318-340-360 and the 383-400-440- again, the hemi was a whole different family.
Ford small block was 260-289-302 which became the 5.0. They had a couple big block variants, and to confuse things more, they made a 351 engine in both big blcok and small blocks, sort of like Chevy's 400. In the Ford world it was Clevland or Windsor for the 351-
HTH- I have lots of useless trivia, I remember less and less as I get older2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
Originally posted by Wild WillyMost manufacturers build engine groups or families- the small block chevy SBC, was a single casting that could be bored to different cylinder sizes and use differing crankshafts and could be built as a 283, 305, 327, 350 and even a small block 400- externally all the same, used same manifolds, distributors, etc.- the big block was a different casting, and, depending on what piston diameter it was bored for and what crank was used, could be a 396, 427 or 1 454- the transmission bell housings and engine mounts were different for small block/big block-
In Fords there were 3 351s. A Windsor, Clevland a a Modified. The modified also came in a 400. They also had a 360, 390, 428. And add in the SOHC 427 side oiler. Then there was a 429/460. My engine bulding neighbor buddy built a 700+ cubic inch 460 motor that put out something like 1500 horses on pump gas.
Cadillac had a 502 cid.
Mercury Marine takes a 454 chevy and bores it out to 496. http://www.mercurymarine.com/engines...s/mpi496ho.php2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
