since its been brought up a few times;....thought i would post this
#05-03-10-020A: Use of Nitrogen Gas in Tires - (Jan 3, 2008)
Subject: Use of Nitrogen Gas in Tires
Models: 2008 and Prior GM Passenger Cars and Trucks (including Saturn)
2008 and Prior HUMMER H2, H3
2008 and Prior Saab 9-7X
This bulletin is being revised to add the 2007-2008 model years. Please discard Corporate Bulletin Number 05-03-10-020 (Section 03 -- Suspension).
GM's Position on the Use of Nitrogen Gas in Tires
General Motors does not oppose the use of purified nitrogen as an inflation gas for tires. We expect the theoretical benefits to be reduced in practical use due to the lack of an existing infrastructure to continuously facilitate inflating tires with nearly pure nitrogen. Even occasional inflation with compressed atmospheric air will negate many of the theoretical benefits. Given those theoretical benefits, practical limitations, and the robust design of GM original equipment TPC tires, the realized benefits to our customer of inflating their tires with purified nitrogen are expected to be minimal.
The Promise of Nitrogen: Under Controlled Conditions
Recently, nitrogen gas (for use in inflating tires) has become available to the general consumer through some retailers. The use of nitrogen gas
to inflate tires is a technology used in automobile racing. The following benefits under controlled conditions are attributed to nitrogen gas and its unique properties:
• A reduction in the expected loss of Tire Pressure over time.
• A reduction in the variance of Tire Pressures with temperature changes due to reduction of water vapor concentration.
• A reduction of long term rubber degradation due to a decrease in oxygen concentrations.
Important: These are obtainable performance improvements when relatively pure nitrogen gas is used to inflate tires under controlled conditions.
The Promise of Nitrogen: Real World Use
Nitrogen inflation can provide some benefit by reducing gas migration (pressure loss) at the molecular level through the tire structure. NHTSA (National Highway Traffic Safety Administration) has stated that the inflation pressure loss of tires can be up to 5% a month. Nitrogen molecules are larger than oxygen molecules and, therefore, are less prone to "seeping" through the tire casing. The actual obtainable benefits of nitrogen vary, based on the physical construction and the materials used in the manufacturing of the tire being inflated.
Another potential benefit of nitrogen is the reduced oxidation of tire components. Research has demonstrated that oxygen consumed in the oxidation process of the tire primarily comes from the inflation media. Therefore, it is reasonable to assume that oxidation of tire components can be reduced if the tire is inflated with pure nitrogen. However, only very small amounts of oxygen are required to begin the normal oxidation process. Even slight contamination of the tire inflation gas with compressed atmospheric air during normal inflation pressure maintenance, may negate the benefits of using nitrogen.
