just wondering how many miles tell ur engine is worn out,or starts to wear out,and how u can prevent this,,,,,thanks
miles
miles
2000 red vw jetta,86k stock
1995 firebird formula ws6 clone,crashed,frame damage ,soldTags: None
uh...that's tough to say.
I got 269K on my engine with no problems...no leaks or oil burning.
Joe had 129K on this LT1 and when he peered into the cylinders it still had the honing on the walls...
So, when does an engine wear? It starts the minute the key is turned...but with frequent oil changes and proper mantainence wear can be kept to a minimum.
Change the oil every 3K, use appropriate octane levels (nothin but '93 for my baby), change other fluids accordingly, don't drive it into a ditch or bus stop, and regular maintenance = forever theoretically.
But I would say 150K seems do be the dooms marker if anything for most cars even some can go 300K +. My opinion.
2002 Firehawk Sold
I have seen 150 and 80 k mile LT1's torn down, and, yes, you can still see the cylinder honing marks-
Between tighter manufacturing tolerances, and improved lubricants, there is no reason these engines won't go a long time- Taxi companies were typically putting over 300,000 miles on the Caprices- In the northeadt, the body will rust off before the powertrian fails-
Keep the RPM's reasonable, change the oil and filters, and keep them tunes so they running smoothly- fix problems when they are small, for example, easier to have your tires balanced rather than and replacing wheel bearings- same goes with plugs, wires, etc-2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
Originally posted by Jeff_in_AtlMobil 1
I took apart an Lt-1 at 140K miles. It had always used mobil 1 synthetic changed every 3K miles. The cylinders still had the original crosshatch hone and there was no noticable wear.
I've taken apart others at the same mileage and many were already toast, they used cheap oil and changes were not as frequent. Draw you own conclusion.
Originally posted by Joe 1320I took apart an Lt-1 at 140K miles. It had always used mobil 1 synthetic changed every 3K miles. The cylinders still had the original crosshatch hone and there was no noticable wear.
I've taken apart others at the same mileage and many were already toast, they used cheap oil and changes were not as frequent. Draw you own conclusion.2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
I had about 134k on my LT1 when I sold it. I had some accessories replaced...water pump, optispark rebuild, etc.. The tansmission needed a rebuild as well.
The engine itself was great! It was running strong with no problems whatsoever. I should've kept the car and not sold it...ah well.Joe K.
'11 BMW 328i
'10 Matrix S AWD
Should 10W30 be used instead of 5W30? I've been using 5W30 for a while and everytime I look online at oil sites, it seems to suggest 10W30 is the recommended grade for the ol' 3800. Does it matter either way?1997 Pontiac Grand Am, 216k+ miles and still moving fast
2004 Pontiac Grand Am SCT, but 35k on the clock
1983 Male Driver, driving Front Wheel Drive only, for now
Heavier weight oil *may* slightly decrease your mileage, harder to move around. It is sometimes used as a bandaid if you have wear in the engine, to hold a little higher oil pressure.
If you have adequate pressure, particularly at idle, with the 5W oil, use it- you will get like a half a percent better mileage- if you need higher pressure, you can use the 10W- Not sure what the General specs for the 3.4 motor-2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
Originally posted by 3800_FirebirdShould 10W30 be used instead of 5W30? I've been using 5W30 for a while and everytime I look online at oil sites, it seems to suggest 10W30 is the recommended grade for the ol' 3800. Does it matter either way?
Originally posted by Wild WillyHeavier weight oil *may* slightly decrease your mileage, harder to move around. It is sometimes used as a bandaid if you have wear in the engine, to hold a little higher oil pressure.
As Joe said, read the Owner's Manual.Fred
Originally posted by InjuneerOnce they both reach normal engine operating temp, they both exhibit the viscosity of a "30" weight oil.1997 Pontiac Grand Am, 216k+ miles and still moving fast
