I haven't posted in a bit...been working like a dog and trying to complete the mods on the T/A.
Anyway, for those who know me...I can't leave well enough alone...EVER!
I got the T/A running like a top, so of course, it's time to modify again.
I started with simple goals...install AS&M/RK Sports Mid-length headers. Well, that was the plan.
Because everything is off, or is only a few small steps away from coming off, I've decided to replace nearly everything and add some sparkle in the process. Here's the list so far:
* new water pump
* rebuilt the Optispark to like new condition with latest generation cap/rotor (all brass)
* replace all timing cover seals including cover to block seal
* replace all heater and cooling hoses with Goodyear Hi-miler (yes, I did ALL the hoses)
* replace the coolant tank/battery tray
* replace EGR (emission) lines with new rubber
* replace plugs and wires (OTVC)
* replace major A/C components (expansion valve, drier/accumulator, compressor) with new parts (no remans here)
* replace rear main seal
* replace oil pan gasket
* flush/fill power steering system
* replace T-56 tranny fluid
* replace alternator
* replace valve covers with polished, smooth aluminum covers
* replaced all seals with Neoprene Fel-pro reusable ones
* flush/fill cooling system including heater core
* reflash ECM with hi-po professional calibration (o2 sensors...hmm, where'd they go (LOL)
* covert dual cat setup to single hi-flow system
* install Aeroforce Interceptor dual gauges to monitor everything
* install rag joint eliminator kit
And for the sparkle: (after 50 hours of work to measure and catalog everything)
* replace nearly every visible nut, bolt, and screw in the engine compartment with polished stainless steel hardware (even hardware on the hood)
* replace all spring clamps on hoses with hand-polished worm-drive clamps
* polished the fuel rails, intake, etc.
* install polished alternator with polished fan and pulley
* paint/polish (?) accessory bracket, hood hardware, etc.
I'm shooting for a reliable 350 hp at the flywheel. As I was already at 330 - 335, I'm pretty confident these latest mods will get me there.
Perhaps in another few years, I'll open up the motor with a stroker package and heads/cam. We'll see...
* new water pump
