My brother just purchased a '03 Z06 with 23K on the clock. Anyhow, is there anything he should know about the car? I am pretty sure those came with Mobil 1 synthetic from the factory so I told him about that. Anything else? He went from a decade of Toyota 4-Runners, to a Honda Civic, to this....hopefully, he wont kill himself!!!
Questions about the C5 Z06
'77 K5 rock-crawler project
Thomas JeffersonTags: None
Just tell him to be careful.
If he works on the car himself then make sure he has the Lift pads to raise and lower the car. The basics about how much Fluid everything takes. Other than that Its the same as a LSx F-body. With the exception of the 50 extra HP and couple hundred pounds less weight. Also the fact that the Transmission is in the rear.
Very Very nice car. My all time dream car. Ill take a normal C5 (ZO6 or not) as long as its a C5! ha ha haEddie
2000 M6 Trans Am
Tune+exhaust=344WHP
There are a few gremlins that pop up. i saw a list of about 15 of them. I'll have to go find the list.
One thing to check is make sure the A/C drain tube is flowing. It comes out by the starter. If it gets plugged it will back water up and drip on the BCM. I took my BCM and put it in a zip lock freezer bag. It's not sealed on the end where the wires go in but if water drips on it it will at least run off rather than go inside and short the BCM.
There is a TSB on the steering wheel column lock. Go by a dealership and get them to run the VIN for recalls and that TSB. If it hasn't been done it will fail. He might want to go ahead and get it done.
I'll think on it some more and get back to you.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Oh the oil drain plug is in the front of the motor so you can't put the front on ramps to change the oil. The car has to be level or downhill. I made some 12 foot long ramps out of 2"X12"X12's and use them on my side driveway which is down hill. With the hill and the ramps the car is level.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff_in_AtlThere is a TSB on the steering wheel column lock. Go by a dealership and get them to run the VIN for recalls and that TSB. If it hasn't been done it will fail. He might want to go ahead and get it done.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
I will tell him about the recall. He is pretty lucky...he picked up the car from his boss who owns the Remax Reality Office where he works so he can ask any question any time. The guy sold it to him because the ZR1 is on order.'77 K5 rock-crawler project
Thomas Jefferson
Originally posted by markd79taI will tell him about the recall. He is pretty lucky...he picked up the car from his boss who owns the Remax Reality Office where he works so he can ask any question any time. The guy sold it to him because the ZR1 is on order.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
FYI the C5s had the same high fan temps 226/235 as the f-body. I had mine reprogramed to 190/200 and put a 160 t-stat in it.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Here is the thread I was talking about for fixing gremlins on the C5. Save it somewhere.
http://forums.corvetteforum.com/show....php?t=18170902002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
One of the other things I have heard a lot of is crazy electrical problems. A LOT of them are caused by a bad grounds or corrosion on connectors. Here is a thread that talks about that. The grounds are kind of an interesting issue because it looks like they are a self tapping screw screwed into the frame and in a lot of places the frame is painted so you only get the screw thread to transmit the ground. It doesn't take much for them to not work. Sanding the paint off behind the ground and a star washer will help them dig in and make a good contact. When I get time I am going to go through all of mine before a problem happens. Oh and I use silicone dielectric on my connectors and spark plug wires. That will stop the corrosion.
http://forums.corvetteforum.com/showthread.php?t=8968752002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
That's about all I got.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
