To make a long story short I took my used 04 Silverado to the dealership about 1 1/2years ago before gm certified warranty ran out to have it looked at for engine noise. They pressure tested it and checked the oil for contamination every thing came back fine, so I ignored the noise . Lately its been using alot of coolant and my last oil change started loosing alot of pressure w/only 2,000miles on it. I kinda thought something was going on but thought maybe there is a small leak at the waterpump and chnged the oil w/mobile 1.
Untill today I started it up to go to work and it sounded like there was no oil in it at all, after a couple minutes it sounded fine though. It made the same noise when I left work too.
So I get home and do some research, looks like gm issued a tsb for castech heads that crack internally causing coolant to seep through them and contaminate the oil. I have all the symptoms, unfortunetly its not a recall and my warranty is up. Should I go right back to the dealership and complain, call gm or is there no hope?
Kinda sucks that I owe $12,000 on it still I've actually considered trading it in, this will be the last gm I own and I've been a diehard gm fan for over 10years.
on my mechanic, gm should have do something about this if it is the cracked heads. Although they probly wont then I'll have to figure out my next move, I told my mechanic that I changed the oil early last time cause it was loosing pressure (thought maybe it was the walmart oil/fram filter). Last month I put in mobile one with an a/c delco filter, thats only got about 1,000miles on it and I've put about 1gal. of coolant in since August, and its almost empty already, and the about engine's startup noise. I didnt say anything about the possible cracked heads/heads, I'll see what he comes up with and go from there. I hope what ever the problem is gm will help out with it, I'd take a huge hit if engine turn out to be toast........ anyone know about how much it would cost to have a new/rebuilt one installed?
