Well, I'm finally getting to the point of getting my Jeep squared away. First is a custom tank with baffling and an in-tank pump for the FI kit. Now, its a TBI setup using a GM TBI unit. I'm not sure on the part # right now, I'll add it in later. Now, the problem I have right now is that I'm trying to find the correct in-tank pump to get. Howell, the company I got the kit from, said to get one that supplies up to 60 PSI. But, everything I read elsewhere says 14 PSI at idle and up to 30 PSI under load. So, can anyone help me with this? I appreciate all help. Also, this is probably the first of many threads to come on my Jeep.
Custom fuel tank for my Jeep
Steve
87 GN - its just a 6... Mods
Tags: None
See, that's what I'm finding too. I'm gonna pop the hood and see if I can find a part # on the TB to see what light it sheds on the topic. Thanks Joe.Steve
i had a tbi bird, get a 454 unit, bigger injectors and body, also my PSI was set at like 9? and 14 underload. hit up the third gen board theres a whole section bout tbi and even tuning it
www.thirdgen.org
btw, use a TPI pump, will flow enough for the motor2009 Honda Civic EX- the daily beater
Originally posted by Trash mani had a tbi bird, get a 454 unit, bigger injectors and body, also my PSI was set at like 9? and 14 underload. hit up the third gen board theres a whole section bout tbi and even tuning it
www.thirdgen.org
btw, use a TPI pump, will flow enough for the motorSteve
454 pump? if you use the 454 TBI unit, its actually bigger then the 305/350 unit, i forget the specs but most guys use the TPI fuel pump as it flows enough for TBI units. as for mods, just polish the tbi unit, it will flow a little smoother and if you add a injector spacer it will help with some power.2009 Honda Civic EX- the daily beater
Originally posted by Trash man454 pump? if you use the 454 TBI unit, its actually bigger then the 305/350 unit, i forget the specs but most guys use the TPI fuel pump as it flows enough for TBI units. as for mods, just polish the tbi unit, it will flow a little smoother and if you add a injector spacer it will help with some power.
