How to Use Different Types of Erectile Dysfunction Pills
There are several ED pills available, and understanding how to use them can help you achieve the best results. Here's a quick guide: 1. Sildenafil Citrate (e.g., Kamagra)
Have any experiences or questions about using these pills? Share them below!
- When to Take: 30-60 minutes before sexual activity.
- Duration: Lasts about 4–6 hours.
- With or Without Food: Best on an empty stomach; high-fat meals can delay its effects.
- Dosage: Typically 50mg, but your doctor may adjust it to 25mg or 100mg based on your needs.
- When to Take: At least 30 minutes before sexual activity. It can also be taken daily at a lower dose (2.5mg or 5mg).
- Duration: Effects last up to 36 hours, earning it the nickname "The Weekend Pill."
- With or Without Food: Can be taken with or without food.
- Dosage: Typically 10mg, adjusted to 20mg or 5mg based on effectiveness and tolerance.
- With or Without Food: Avoid high-fat meals for better effectiveness.
- Dosage: Usually starts at 10mg, which can be adjusted by a doctor.
- Sexual Stimulation Required: These medications enhance natural responses, so arousal is necessary.
- Do Not Mix with Nitrates: Avoid combining these pills with nitrate medications, as it can cause a dangerous drop in blood pressure.
- Limit Alcohol: Excessive alcohol can reduce effectiveness and increase side effects.
- Consult Your Doctor: Always seek medical advice to determine the best option and dosage for you.
