The Soni Circuit is easy to miss when you're busy tearing across Japan, but it's one of those spots you'll want to pin on the map early. It's tied to Time Attack runs, seasonal tasks, and a few challenges that can help with progression, especially if you're trying to build up Forza Horizon 6 Credits without wasting time on events that don't move the needle. The track rewards clean driving more than wild speed, so it's a good place to test whether your car setup actually works.
What Makes Soni Circuit Worth Visiting
Time Attack events feel different from standard races. There's no pack of cars blocking your line, no messy first corner, and no need to fight AI drivers. It's just you, the circuit, and the clock. That sounds simple, but you'll quickly notice every missed apex and every late brake. Soni Circuit is popular because it gives players a compact, focused place to practise lap control. If you enjoy shaving tenths off a run, this track gets under your skin in a good way.
How to Find the Track
You'll find Soni Circuit in the Takashiro region, up in the northwestern part of the map. Open the world map and look for Hirosaki Castle first. It's the easiest landmark to spot because of the water around it. Once you've found the castle, move your view south and look for a small race facility nearby. That's the circuit. Set a waypoint before driving over, because the roads around Takashiro can pull you into mountain routes if you're not paying attention.
Challenges Connected to Soni Circuit
The circuit matters because it's used in current seasonal and monthly objectives. Monthly Rivals sends players there to post a clean run and measure their pace against a set target. You don't need to be a leaderboard hunter to finish it. Just keep the lap tidy and avoid heavy mistakes. The Ultimate Driving weekly task also uses Soni Circuit, with players asked to complete three laps in the 2020 BMW M2 Competition Coupé. The car suits the layout well, so the challenge is more about finding the place than surviving the drive.
Driving Tips for Better Runs
Don't attack the first lap like it's the only one that counts. Use it to learn the braking points. Soni Circuit punishes messy throttle use, especially if your car is tuned too stiff or geared badly for corner exits. Brake a touch earlier, straighten the car, then get back on power smoothly. It's not flashy, but it works. If you're testing different builds, try changing one thing at a time. Tyres, suspension, and gearing can all make a difference, but swapping everything at once just makes the car harder to understand.
Final Thoughts
Soni Circuit is one of the more useful Time Attack locations in Forza Horizon 6 because it links practice, rewards, and seasonal progress in one place. Once you know it sits south of Hirosaki Castle in Takashiro, getting there is simple. It's also a solid testing ground for new tunes and fresh Forza Horizon 6 Cars, especially when you want to see how a vehicle handles tight corners instead of just chasing top speed across open roads.
Final Thoughts
