I need the t56 clutch line for a 94, Mostly the fitting, i can have a local shop make me the custom line it can be busted, I just need the fitting to make this thing work for me.
email me benrus18@hotmail.com
I need the t56 clutch line, Mostly the fitting, line can be busted, I just need the fitting to make this **** thing work for me.
I'm not sure what you need but for now I'll assume you are needing a hydraulic line clamp for the hydraulic hose between the master and the slave cylinder.
First you need to specify what you have because the system is different on the 93-97 vs. 98-02 cars.
Second the 93-97 comes as one piece and I'm not sure how you would reconnect the line without having a clamping machine. A simple SS clamp would not hold for the pressures being applied.
Oh and third please remove the curse word. They are not allowed per the agreement you signed that allowed you to post here. Obviously you are frustrated but it is still no cool here.
i need the hole clutch line so if any of yall know anywhere online that sells them i would apprieaciate it, i have one from the junk yard that has been cut with the fitting on it if that could be of some use, its a steal braided line from a 30th anniversary edition
