I am making remote bleeders for the clutch. With this bleeder you can run it up to the engine compartment or out under the car to bleed the clutch. It also has a speed bleeder on the end so it's a one man operation to bleed the clutch. I am only getting top of the line parts to make them. One of the problems with making them is getting the fitting for the slave cylinder that will seal and not leak since it's not a machined surface. I have found what they call a bonded washer that will seal under high pressure to use on the fitting. I also have found a sealant to use on the threads that will not break down from the brake fluid. This provides a double seal for the fitting. I will be selling them for $75 with Free Shipping. Here's some pictures of it installed.
