Parting out wrecked 1995 Z28, 125k, larger parts listed, email or call for other parts.
*Sold are injectors, fuel rail, exhaust, headers, gauge cluster, spare tire, jack.
- Block, stock LT1 350, 125k, some rust, will hot tank and magnaflux at extra charge upon request
- Stock LT1 350 rods, pistons, crank, 125k miles
- SPEC Stage 3 ceramic clutch, only 1k miles before wreck shows no wear
- Entire front bumper (red, few scratches, needs paint), reinforcement, headlights & bracket,
- A.I.R. (Smog) Pump...fairly new, was replaced in 2002 for T.S.B.
- Water Pump, AC Compressor, PS Pump, 140 amp Alternator, all functional when removed.
- Stock Cam, Rockers, Timing Chain, Lifters, Pushrods.
- 1993-1996 ASCD Big Block hood painted Bright red with Black scoop.
- Intake Manifold, stock LT1 350
- Heads, stock LT1 350, ported, polished, flow matched, milled .010, 3-angle valve job...included are dual valve springs and stock valves.
- T56 Tranny, 125k, all gears functional when removed. Included is bellhousing.
- Hurst Short Throw Shifter for T56 6-speed
- T-Tops, 1993-2002 Camaro/ Firebird Charcoal interior
- Seats, from 1995 Z28, charcoal, drivers (power) and passengers show normal wear, rear seats perfect.
*Will provide pics upon request of any part listed.
Contact me as follows, I will get back to you ASAP:
Email: Jameskz28@sc.rr.com
Phone: 803-316-6331
Phone: 803-316-6331
), ASM LT's, Meizer WP, 3:73's, Eibach Pro Springs, Poly-graphite Bushings, KYB shocks, BMR LCA / Pan hrd & relocation brackets, Budnik 17x9's., 1LE sways & ALM. Drive Shaft. And on and on and.....
