1987 project T/A
  • 1987 project T/A
    1987 Transam with 120K miles (stock engine died in 1997 or so)
    Single owner bought new in Southern CA
    Blue with silver bottom exterior and gray interior
    Factory AC, PS, PB, Tilt, Cruise, Digital Dash, RW Defog., Int. Wipers
    T-Tops
    5-speed
    I was forced to declare it junk in the communist state of California which does not allow you to sell a vehicle “as-is”.
    Modified parts on car at this time:
    Factory 16” wheels which are painted blue inside and chromed on face surface
    Hurst shifter
    Herb Adams panhard bar
    Koni springs/shocks (red)
    HPM LCAs
    Banks cat-back (two pipes exiting drivers side)
    Poly bushings throughout
    Smothers Bros. 12-bolt rear with 3.55 gears and Wilwood 12" disks (freshly gone through, new seals/bearings)
    Newly rebalanced driveshaft with new U-joints
    Cyberdyne speedo calibration box
    Condition/needs:
    The car has sat for about 8 years. Sometimes outside and sometimes inside. Needs some dents and one big ding in pass. door fixed and then the whole thing painted. Needs new front facia or may be able to fix tear in foglight hole? Hood is off due to removal of engine. Needs parking brake cabling work to hook up to Wilwood system. Noticed small leak in front brake fluid somewhere(was going to replace hoses with stainless). Was eventually going to get a stouter tranny. Interior so so for carpet, seats, dash, headliner. Driver seat 2 tears. Steering wheel leaking something. I put a bunch of Dynamat type stuff in the rear section. I installed MB quart separates in rear panels. Kenwood unit in dash and cd changer loose in rear. AC is still intact and worked last time the car ran. All dash items worked good. Power door locks did not open correctly all the time (another project). Don’t know about leaks since it does not rain much here.
    Out of car :
    ZZ3 shortblock, engine basically new
    TFS heads
    Edelbrock runners and baseplate (mild home port)
    Edelbrock TES headers coated (home ported to match heads)
    AFPR
    24# injectors (near new)
    52mm TB (original pro ported)
    Crane 99846 springs (new and on heads)
    Crane clone 1.6 full-roller rockers (near new)
    Mr. Gasket chrome valve covers modified for rocker clearance (used)
    Intake gasket set
    Ported plenum (original)
    K&N filter and custom intake pipe (replaces box from MAF to TB)
    Centerforce Gold clutch with 30K miles
    Accel Power Programmer piggyback module and Calmap software (maps for 305 and 350)
    Hypertech chip for 305, FIS chip for 350
    Random 3” cat (new)
    Distributor Accell
    Wilwood pads (new)
    Oil Temp and Fuel Pressure gauges with pod/accs.
    Heated O2 sensor and harness
    Lower temp secondary fan switch
    New knock sensor and module for 350
    Starter from ZZ3 (rusty outside) very heavy duty
    2 different flywheels stock from 305 and one was on ZZ3 (very heavy)
    Stock stuff air box/MAF/O2/starter/more forgotten
    All metal emission stuff (air pump is frozen and some lines need replacement)
    Set of Goodyear High-Miler hoses
    Center console (good shape)
    Radiator
    Misc. hoses/bolts/brackets (should be complete for accs.)
    Alternator (good shape)
    Front facia (needs repair/relacement)
    Front plastic parts under facia all good
    Moroso spark plug wires (OK but was going to replace)
    New heavy duty water pump
    SFCs
    Shop manual
    Things that need to be done:
    Install Wilwood proportioning valve
    Do something with the emergency brakes
    Fix interior
    Install pod gauges
    Install heads (need gaskets and correct length pushrods)
    Install intake system (need to get allen head bolts for runners)
    Bolt up headers (need to get Stage-8 bolts)
    Install engine
    Hook up all the millions of brakets/hoses/vacuum lines etc. (need misc. small things)
    Note: Engine can be run MAF or MAP since conversion is very easy
    Hook up exhaust (Y-pipe has dinged end that goes to converter so it may not slide on perfectly)
    Drive around with no hood and no front terrorizing neighborhood
    Assemble rest of exterior
    Have it painted
    Drive it and have fun, at least that was the original plan. Now I would like to sell the whole thing to someone ready for a project. I have moved a couple times so I may have lost something in the list above, but the new buyer will get everything I do have for it plus a 20 ton press and engine stand.
    $5500
    Damn if only I was closer, id take it in a second, but I dont really want to drive my kenworth from alberta to cali to get the car and haul it back. too bad sounds like a wicked deal.
    Eric W.
    89 Firebird Formula WS6
    Accel/Lingenfelter Super Ram
    6.2L/382.97 ci
    Custom PROM Dyno tuned
    WCT-5 speed
    BW 9-bolt Posi 3.45
    Boss MS 18" Rims
    Custom Dual exhaust
    1LE upgrade
      so where in cali are u?
        Valencia 91354
          UPDATE
          T-Tops
          5-speed
          Hurst shifter
          HPM LCAs
          Condition/needs:
          The car has sat for about 8 years. Sometimes outside and sometimes inside. Needs some dents and one big ding in pass. door fixed and then the whole thing painted. Needs new front facia or may be able to fix tear in foglight hole? Hood is off due to removal of engine. Needs parking brake cabling work to hook up to Wilwood system. Noticed small leak in front brake fluid somewhere(was going to replace hoses with stainless). Was eventually going to get a stouter tranny. Interior so so for carpet, seats have dry rot on tops of back seats and seating area in front, dash ok because it has a dash mat, headliner ok. Steering wheel leaking something. I put a bunch of Dynamat type stuff in the rear section. I installed MB quart separates in rear panels. Kenwood unit in dash and cd changer loose in rear. AC is still intact and worked last time the car ran. All dash items worked good. Power door locks did not open correctly all the time (another project). All glass in good shape windshield normal pitted from 10 years in desert. Don’t know about leaks since it does not rain much here.
          Out of car :
          TFS heads
          ARP bolts for heads
          AFPR
          Crane gold 1.6 full-roller rockers
          Intake gasket set
          Random 3” cat (new)
          Distributor Accel Billetech
          Wilwood pads (new)
          Radiator
          SFCs
          Shop manual
          Fix interior
          Install pod gauges
          Bolt up headers (need to get bolts)
          Get a nice harmonic balancer
          Install engine
          Have SFC’s installed
          Have it prepped and painted
          Drive it and have fun, at least that was the original plan. Now I would like to sell the whole thing to someone ready for a project. I am moving on to a C5. I have moved a couple times and I am pretty sure I still have everything, but the new buyer will get everything I do have for it plus a 20 ton press, engine stand and 4 wheel dollies.
          $4500
            One more try before parting out.
              Parting out. By far, the most important thing to get rid of is the bulk of the car itself. It is sitting with basically the engine/accessories out. I am looking for $1500 for the 12 bolt and will let the entire rest of car it is attached to go for $300 more as it sits without engine/accessories/stereo.
                I have had interest in certain parts, but that still does not help empty that bay of the garage. So I think I'll push it onto a trailer and take the parts off and take it to a salvage yard. Unless someone local wants what is left of the shell for free and is willing to help me, or wants the car as it sits for $1500.
                  I am in need of a crossmember for an 84 firebird. Just wondering if it will fit and if you would be willing to sell it.
                  Thanks
                  Chris
                    Hopefully someone else can chime in on the fit. I don't know if '87 fits '84 and if A4 is same as T5?
                      Its the same. And there is A Private message for you GeorgeB, I am interested in a few of the parts!
                      Eric W.
                      6.2L/382.97 ci
                      WCT-5 speed
                      BW 9-bolt Posi 3.45
                      Boss MS 18" Rims
                      Custom Dual exhaust
                      1LE upgrade
                        Thanks DeWynter,
                        Then yes, i would be interested in buying your crossmember, you have a pm
