Right now, stubs are moving fast in MLB The Show 26, and you don't have to sit there flipping cards all night to make progress. If you're smart with your time, MLB 26 Stubs can come from a mix of roster bets, repeatable gameplay, and rewards you may already be close to finishing. The key is not chasing every shiny card on the market. Pick two or three good methods, stick with them for a few days, and you'll usually see your balance climb without it feeling like a second job.
Roster Update Plays Still Matter
Roster update investing is still one of the best ways to make serious stubs, though it does take a bit of patience. The idea is simple. Buy players before an upgrade, then benefit when their quick-sell value jumps. An 84 overall moving to 85 or 86 can be a big deal if you bought enough copies at the right price. Don't just follow hype, though. Look at recent form, playing time, and whether the player has been getting steady attention from the community. It's also safer to spread your stubs across several names instead of dumping everything into one guy and hoping for the best.
The deGrom Showdown Is Worth Your Time
The Jacob deGrom Showdown is a strong earner if you can hit high velocity. It's not mindless, and that's actually why some players like it. You draft your squad, work through the moments, and try to finish the run for a sellable deGrom reward that can bring in a nice chunk of stubs. Left-handed bats and switch hitters help a lot, because deGrom can make righties look silly with that fastball. Take contact perks when you see them. Clutch boosts are useful too. If you're finishing runs in about half an hour, the hourly profit can be better than most casual grinding methods.
Diamond Quest Has Real Value Again
Diamond Quest is easy to ignore when everyone is talking about Showdowns, but the rewards have climbed back into a decent price range. Cards like Ozzie Smith, Johnny Damon, Fred McGriff, and Luis Castillo can still sell well depending on the market. The best part is that Diamond Quest breaks up the grind. You're not staring at the same pitcher every run. Some players lean into bunting to speed things up, and while it's not glamorous, it works if you know when to use it. Even after tax, a clean run can leave you with a very respectable payout.
Use Programs While They're Still Live
Programs are the quiet stub makers. They don't always look exciting at first glance, but packs, XP, player cards, and progress rewards all add up. If a Multiplayer Program or Spotlight path is close to expiring, knock out what you can before it disappears. You may pull nothing special from the packs, sure, but they're still free chances at cards you can sell or exchange. Program rewards also help you move along seasonal paths, which often leads to even better packs later. It's not the flashiest method, but it's the kind of steady value players miss when they only focus on the marketplace.
Final Thoughts
The best approach is to mix your methods instead of relying on one grind. Hold a few roster update investments, run deGrom when you're hitting well, and work Diamond Quest or programs when you want something less sweaty. Some players may choose to buy MLB The Show Stubs to speed things up, but you can build a strong balance through regular play if you stay organised and avoid wasting stubs on every new card that drops.
Final Thoughts
