hey everybody. Im looking into replacing, or rebuilding my rearend in my 94 LT1 firebird. It has a 97 model TA rearend, i believe,(thats what the previous owner said at least.) It is grouling pretty bad when you take corners, it has done it for a long time, bout 8 months. I drained fluid, and replaced with Lucas Diff. Fluid, which they claimed is fine for posi's, and topped off with rearend fluid which also claimed on bottle, good for limited slips. Well, It seems like it got louder now, after bout 90 miles.
Any ideas, If not that expensive, what kinda money am i looking forward to spend to rebuild, or whats a good price to look forward to at a salvage yard.
Thanks
Thanks
has ever done that! Only thing they ever do is leave nice twin black stripes on the pavement
) GM recommended two different lubricants for the standard and "posi" rears. There used to be a metal tag under the fill plug that reminided you it was a limited slip and needed special lubricant. I guess they decided to use the same lube in all diff's, and then have the "LSD" additive for the posi's.
