OK, here is the picture I promised. http://www.claire-marie.net/LT1vsLS1_brakes.JPG I'm not going to embed the picture here because it is 2.33 meg so you might not want to open it if you have dialup.
The LT1 is on the left and the LS1 is on the right.
Too bad the guy at Tennessee auto gave me 2 left side calipers and no right side caliper. Grrrr. I'm going to have to have a talk with that boy.
Everything went pretty well other than that with the exception of one thing. If you get the parts to convert them from LT1 to LS1, make sure you get the little metal brackets that holds the end of the rubber brake line where it mounts to the frame. The brake line for a LS1 will not fit the LT1 without some grinding/drilling. Another note is a pickle fork will not separate the ball joints. I had to use a 2 prong gear puller. The pickle fork will mess up the boot on the ball joints and the tie rod ends. I just went ahead and replaced the tie rod ends since they were only $11 each at AutoZone.
Also, if you do end up putting your stock 16s on as a test fit, please let me know what the result is. If they'll fit, then I'm definitely going to add that to my list of upgrades. Thanks for the info Jeff, you da man
