Whenever i first start my car and the temp is still below 160, when i release the clutch it idles out at what i believe to be normal operation. But when the temp hits 210 and i let the clutch out there is a shaking in the motor/tranny that can only be described as how it feels when you are stalling out. After the initial idling out every gear shifts smoothly with no problems. My clutch has about 5k miles on it but the flywheel is original. About 10k miles ago the water pump went out but i didn't replace the opti thinking it wasn't harmed. But now I can tell that there is a small amount of reduced performance unless I am just imagining it. Could this be a bad opti or the need for a new flywheel? Those are the only two things I can think of it being. Any suggestions are greatly appreciated guys.
Thanks
Thanks
