Inflating Tires With HELIUM
  • Inflating Tires With HELIUM
    What would happen if you inflated all 4 tires with helium instead of oxygen? Would it make the car SLIGHTLY lighter which would mean faster.
    94 Formula LT1 (Aqua Metallic) - Auto. - 104,000 miles - Charcoal Leather Mods: Magnaflow Muffler, Lingenfelter CAI, MadZ28 Tune, 160F Hyp. T-Stat., 1LE Elbow, & Summit Cutout. Options: 155 MPH Gauge Cluster, & 255-50ZR-16 Tires.
    It would leak out quicker than regular air. Nitogen is preferred for temperature benefits.
      Black 98 Z/28 (Taz),Lid,FRA mod, STB,SLP LoudMouth catback .
        Yup, helium molecules move at a much faster rate than oxygen molecules. "On the atomic mass scale, helium molecules weigh 2 units, oxygen molecules weigh 32 units. Big difference! [If we were talking about air instead of oxygen, the average weight of molecules of air is 29.]"
          some 1 likes science... lol
          1967 Camaro "Project"
          1972 Chevelle "454"
          1979 Trans Am "Project Ls-1"
            Hydrogen would weigh half as much as helium . Only use it if you really need that last 1/2 ounce weight reduction.
            1989 TA
            Flowmaster exhaust
            Ghetto CAI
            1994 TA GT
            K&N CAI
            Magnaflow catback
            www.nkyfba.com
              probably work better with a tube in the tire. less spots for it to leak
              Richard Harvey Jr.
              '94 T/A LT1 (stock) - SOLD
                Last I checked, the atomic weight of Helium was 4.
                Rough guess as the volume of a tire.... assume 24" average (not outside) diameter, 12" section width, 6" height = approx 6.28' X 1.0' X 0.5' = 3.14 cubic feet.
                At 32degF, 29.92"Hg (14.7psi(a) )the density of air is 0.0808 LB/cu ft. At 32psi(g) inflation pressure, that would be (46.7 / 14.7) x 0.0808 = 0.2567 LB/cu ft.
                One tire contains roughly 3.14 cu ft X 0.2567 LB/cu ft = approx 0.81 LB of air.
                Changing to Helium would reduce that to (4 / 29) X 0.81 = 0.11 LB of Helium.
                Weight savings for 4 tires (assuming no spare) is 2.8 LB. In a 3,600 LB F-Body pulling 13.800 @ 100.0 mpg, the weight saving would improve the performance to 13.7968 @ 100.0255
                Have fun....
                  Have fun....
                  HAHAHHAHAHAHAH!!!! That was awesome!
                    Fred, you're right, He has an atomic weight of 4, and O of 16. I'm guilty of copying and pasting a quote without reviewing the info. Sorry...
                      No big deal... you mixed up the atomic number and the atomic weight. Happens all the time
                      And, while the atomic weight of oxygen is 16, it is present in the diatomic form O2 with a "molecular" weight of 32. Ditto with N2 = 28.
                        Have fun....
                        I know who to talk to when I have have a chemistry exam
                        1997 6-spd WS6 Trans Am
                          Have fun....
                          Oh, but wait Fred... since it's 2.8 lbs of rotating mass, aren't its effects calculated a little differently?
                            well...for one thing.. you could get on your knees at cars shows, remove the valve core and suck in the hellium and talk funny for your friends!!!!!!!!!!!!!!!!!!!!
                            Nitrogen has been used for years in aircraft tires and race car tires . it is not affected by temps and does not bleed out thru the porus inner linner nearly as fast as air...
                            its comming back now. many tire stores offer nitrogen tire fills in lieu of air.
                            we are looking at doing it in the govt. fleet. if you want to read the bennies...here's the whole scoop from Bridgestone:
                            go hear, and download the pdf and educate your bad selves......
                            http://www.retread.org/packet/index.cfm/ID/281.htm
