I remeber a while back someone posted that they were hearing a squeeling when they are turning and that the rear diff was the problem. If you get this problem can it be fixed by getting just a new differential? Because I have had my rearend rebuilt once and i am starting to get some of the same symptons it gave me before (rearend noise, squeeling brakes, and squeeling when turning). Is it possible to fix this problem completely by getting a new diff, ring set, and all new bearings?
Rear axle assembly question
Pretty much any problem can be fixed internally without replacing the whole assembly......96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
