I've got the intake just about ready to remove and what do I find? The drivers side valve cover gasket is not under the valve cover along the top edge. It is hanging out, along the edge of the intake manifold. This does not account for the oil running down the passenger side rear of the block, but it does make me want to replace the valve cover gaskets in addition to resealing the intake manifold. Has anyone else run accross this? Are there any special tips on replacing the valve cover gaskets?
Also I purchased a "muffler bandage". I intend to use it to insulate the EGR tube so it gives off less radiant heat. It is a heat resistant, fireproof cover with aluminum tape to wrap it with and wire to reinfoce the job when done. Once it is insulated it will no longe dry out the seal at the rear edge of the intake. It seems like a "rigged" fix, but I'll cut it to fit neatly and it will look professional.
Feedback?
Feedback?
