hey guys anyone can help? ive smoked my clutch so now it slips can i just change the clutch disc or i need a whole new setup ? very low on $$$$ so cheapest way out any sugg?
m6 c lutch help????
cheapest way is to get a new clutch (no other way). you'd have to drop the tranny for this so
get 1 replacement clutch + friends + BEER = Cheapest way to fix your problem. No cheaper way .. unless you'd give your friends water
pics and info
I don't think there is a way to answer the question and be sure without knowing more details that you are not going to know until you get the trans out. If the clutch is wore down to the rivets, it might have worn grooves in the pressure plate and flywheel. Then you will need to do more things. You might can get away with just a clutch disc if nothing else is wrong.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
no one knows?
