I just ordered a set of MAC headers and will be replacing them soon, i figured that while i was under there i should go ahead and do my plugs and wires. I was just wondreing if there were any particular barnd wires and plugs that you would recomend and/or the best place to get them from. Any tips on the headers will be appreciated as well---Thanks
headers, plugs, wires
Black '96 Z28, loudmouth exhaust, Mac mid length headers, crane cams powermax 104227 cam, crane 1.6rr,'s, springs, lifters and pushrods. MSD distributor, slp ultra z hood with air box, bbk 52mm throttle body, march underdrive pulleys, hpp+, 1le sway bars, spohn LCA's and relo brackets, Spohn SFC's, adj panhard bar, bilstein shocks, H&R springs, strut tower brace...Audio-Alpine head unit, MB Quart 6.5" component in the front and 6.5" Boston in the rear w Alpine 75x4 amp, Alpine Type-X 12 in the trunk w/ alpine 1000w ampTags: None
I went with Taylor wires with an over-the-valve-cover kit from Thunder Racing. Keeps the wires away from the MACs just fine.
As for the headers, nothing out of the ordinary to install, but I also had most of the wiring and vacuum lines off so there was more room than usual. The y-pipe didnt mate real well, but it went on after some fighting with it. Depending on what year your car is, your air tubes might have different threads than what's on the headers. I had to buy ones for an earlier year. And MAC's tech support is pretty bad.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
