nfb: With all this talk of other cars, I'm waiting to see this.....
Originally posted by Joe 1320
I thought that would be a great commuter car for me, but hard with my 4yr old. This car and the Solstice should do really well if they don't scrap them.'77 K5 rock-crawler project
Thomas Jefferson
rear wheel drive????Tracy
Originally posted by TraceZrear wheel drive????'77 K5 rock-crawler project
Thomas Jefferson
Now it would be real sweet if they put in the DOHC straight six thats in the Envoy in that little two seater.
Originally posted by Joe 1320I've thought about a Lotus Elise, but the price for the stateside version is a bit hefty.
That saturn and the solstice would be a nice "cruiser" option for someone who doesn't have too much money, but wants a fun daily driver.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
I really dig that car. You would think they could put something a little more stout other than a 2.4L 170hp motor though.
Originally posted by Joe 1320True. But since when do people like us leave things alone? A little added pressure could do wonders.
Apparently the LE5 2.4 Ecotec has a forged crank, forged rods, and oil squirters under the pistons. So it would seem apt to handle more boost, but I have been trying to do a search for which type of piston the LE5 uses, but so far all I have found is just that it is supposed to be a "heavy duty" aluminum piston with a polymer coating on the crown and skirts. Also from what I can see, the static compression ratio appears to be 10.5:1! That probably will limit how much you overdrive the Eaton without running into problems.I wonder why GM chose to go with such a high compression ration?
That car is slick looking. Almost 10K cheaper than an s2k too. I like how GM likes to think the ecotec is the "SBC of generation x."97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Originally posted by Joe K. 96 Zeee!!There's a performance version on the way too!! 253HP from a turbo 2.0L Ecotec is the rumor.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
