Help with cooling issue w/in
  • Help with cooling issue w/in
    The temp on my car will sometimes go up a bit while setting in traffic, but if I increase the rpm's a some the temp goes back down right away. What I'm wondering is could the waterpump be about ready to die and just not flowing fast enough while idoling? Any thoughts or ideas are appreciated.
    Goes up to what? The fans aren't programmed to kick on till 226 deg. That sounds pretty normal.
      get a low temp switch(it alwys help) that dont work, its the pump
        More info w/in
        I have a 160 thermostat and the pcm has been programmed to turn on the second fan at 192 and off at 185. The temp didn't used to go up in traffic, it was always pretty solid. Just wondering if anyone else has had a waterpump do this, or if I need to look elsewhere?
          I have not heard of one failing to pump. The only thing I have ever seen is they start leaking out the weep hole and take out the OPTI.
