Originally posted by raroZ28
Header install... What happened...?
Originally posted by Joe 1320By removing everything, drilling out the broken bolt pieces and fixing the threads with a helicoil. It will probably take a remote drill head ( either flexible shaft or 90º adapter to get into the confined area. That's the only way I know of without removing the head. I've done it, it works.......time consuming and close quarters though.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
That bolt is famous for being broken. Good luck removing it, I was never able to find a tool that could fit in such a small area. That is why I ended up getting the SLP headers that use a different (unused) bolt hole. My broken bolt is still in the head. Are you sure your headers use the same bolt battern as the original manifold, some/many(?) don't?
Sean1994 Z28, 6 spd, LE2 Heads, GM 1.6 RR, .026" head gasket, SLP: CAI-Headers (CARB legal)-ypipe-2 on the left-lightweight flywheel-short throw, Random tech cat, CF dual friction, LT-4 KM.
