jsut pciked one up any tricks to the trade?
opinions on mr clean autodry carwash
I heard it worked great...but um, never really tried it. I live by this rule...if it's too easy, it probably won't work.
Again, I heard raves about the product...
The only negative thing I've heard about it is that it has a tendency to remove wax from the vehicle. So while you could use it "in between" detailing, I wouldn't use it on a regular basis.
Of course, for those of us who don't wax our cars, it's not a big deal
I have used it extensively. I use Zaino and it has not touched it. People may be confused because the final spray does not bead. It just sheets right off. The wax is still there. Basically you spray on the soap and hose it off. Of course you may have to assist with a bit of rubbing if the dirt is heavy. They have the new pro series which is supposed to have higher pressure.
I have washed my car in the hot sun and sprayed it with their filtered rinse and it dries with no spots. After about 10 uses, the filter needs to be replaced. You should see the crap it filters out.
No towel has touched my car since it came out.
Originally posted by JUICEDSSI have used it extensively. I use Zaino and it has not touched it. People may be confused because the final spray does not bead. It just sheets right off. The wax is still there. Basically you spray on the soap and hose it off. Of course you may have to assist with a bit of rubbing if the dirt is heavy. They have the new pro series which is supposed to have higher pressure.
Droool.... That is a nice lookin SS!
I have the kit still in the box in my closet, I think i'll try it on my s-10 this weekend.2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
