Where can you but the Trick-Flow Lt1 elbows.
  • Where can you but the Trick-Flow Lt1 elbows.
    Looking for the trick-flow lt1 elbow.
    Thanks
    trick flow elbow
    Summit has them in three different styles black powder coated, ceramic coated & bare satin. Prices range from 79.95 to 89.95. I just installed one on my 93.Gm wanted 120.00 for the factory elbow & sensor.Heres thier web address SummitRacing.com. Or 1-800-230-3030.
      summitracing.com
        Did you notice a difference with the elbow in lue of the factory model?
        95 Trans Am, K&N CAI, LT4 knock module, Flowmaster exhuast, Grant GT steering wheel, Sony head unit w/sub, Autometer Gauges
          This is coming to you second hand, but from what I've read about other people's experiences, it doesn't help much if at all in the power arena.
          Joe K.
          '11 BMW 328i
          '10 Matrix S AWD
            elbow pwr gain
            Sorry but i can't say if any gain has been noticed.I just purchased my 93 and I'm trying to work out other issues with my ignition system? I bought the car cheap but knowing it had this problem so i'm dead in the water at the moment.I would have to say it probably doesn't add that much pwr.Thought it does elminated the resonator tube and you won't have to worry about it ripping like the factory part.It does dress up the engine compartment if you get ceramic-coated one.
