electrical problem maybe???
  • electrical problem maybe???
    The problem is when I try to start the car nothing happens. I thought it was the ignition switch. But i figured out it has something to do with the gear slector. With the car in park and me turning the key to start nothing happens but if I wiggle the gear slector while in "P" at the same time it starts. Any ideas
    96 Camaro Z28/A4,Vortech elbow,Moroso CAI,Flowmaster.Addco PHR,LCA,160* Stat,pcmforless,1LE Driveshaft,1LE A/C delete pulley,1LE Front sway bar,Strut brace,sub frames, LT4 knock module,255 lph pump,Cutout,
    sounds like your neutral saftey switch is out of alignment, or your switch is bad
    past rides:
    1994 Z28 A4 totaled
      Do you know where it is ??? Thanks
        Here you go.
        Transmission Position Switch
        Richard Harvey Jr.
        '94 T/A LT1 (stock) - SOLD
          Can you adjust this? If so how? or must you buy a new one. Thanks again
            not positive but it should be these two screws loosen them and slide it forward or back, untill to works correctly.
            EDIT
            Here is the procedures from all-data
            REMOVAL
            1. Disconnect battery ground cable.
            2. Remove floor console, then disconnect electrical connectors from switch.
            3. Place shift lever in Neutral position of detent plate, then remove switch attaching screws and switch
            INSTALLATION
            1. Ensure the shift lever is in Neutral, then position switch on shift lever making sure pin on shaft is in slot of switch.
            2. If reinstalling existing switch, rotate switch to align service adjustment hole with carrier tang hole. Insert a 3/32 inch gauge pin and rotate switch until pin drops in to a depth of 19/32 inch. Torque switch attaching nut to 18 inch lbs., then remove gauge pin.
            3. If installing a new switch, torque attaching nuts to 18 inch lbs., then move shift lever out of Neutral to shear pin which is part of new switch.
            Reconnect electrical connectors to switch, then apply parking brake and start engine. Check back-up lights and seat belt warning system for proper operation and ensure engine will start only in Park or Neutral.
            4. Turn ignition off and install floor console.
            Richard Harvey Jr.
              Awesome. I really appreciate this..
