I'm taking my car over to my uncle's garage and putting it up on the lift to do some minor work this sunday and was wondering if you guys had any tips on how to make the job go easier. I have to replace the pilot bearing, install my new SLP flywheel, drain and refill the tranny, change the oil, drain the coolant, reseal my intake manifold, put in my NGK spark plugs
, and clean the maf and k&n air filter. I am getting a pilot bearing puller and I already have a GM fuel line disconnect but I don't know if there are any other specialty tools like this that i will need for the plugs? I saw that SLP has a spark plug socket but wasn't sure if it would be worth the $22. Any input is greatly appreciated guys. Hopefully it won't be too bad seeing as how i will be using a lift and air tools but just the same... Wish me luck on sunday!!!
Ohh and BTW what should i gap my plugs to???
, and clean the maf and k&n air filter. I am getting a pilot bearing puller and I already have a GM fuel line disconnect but I don't know if there are any other specialty tools like this that i will need for the plugs? I saw that SLP has a spark plug socket but wasn't sure if it would be worth the $22. Any input is greatly appreciated guys. Hopefully it won't be too bad seeing as how i will be using a lift and air tools but just the same... Wish me luck on sunday!!!Ohh and BTW what should i gap my plugs to???
But as they say in China. . . . Good Ruck.
