Anyone every had a problem starting thier ls-1 after it has been sitting for a week or so? It seems that mine needs a new starter after only 41k.
Starting Problem
BLUE2000Tags: None
why do you assume the starter? You didnt give much of a description of the problem, but a hard start after sitting usually winds up to be the battery or some kind of parasitic draw.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
11.6 @ 123mph (1.6 60' - getting there)
BLUE2000
You were right. It was simply a battery problem. My car is not in my current posession and I was told that the starter was going by the current driver. A simple test was done and it was only the battery.
