injector install question...
  • injector install question...
    ok installed my 30# injectors but i have a few questions... old injectors came off no problem, however one of the old injectors that i had in my box at the end had the oring on the nozzle side missing. i checked the injector bores an saw no sign of it... could it have fallen into the intake!? could i pull off the t.b an get a flashlight see if i could find it, im not 100% its in there though. i talked to a buddy of mine he said it would burn up, however im worried if it did fall in then it would mess with the valves. im not 100% that it was on there when i took it off, i didnt notice until the end.... another thing is injector 8 and 7... they are seated higher then the others, is that normal? and one more thing, the brown plastic shims above the injector nozzles are visible, is that normal? thanks alot!
    -chris
