I need the name for a water hose. It's the one that comes from the front of the engine and has a metal piece on it that has some sort of adjustment on it. It's apporx. a 1 inch hose. It continues to go down by the a/c compressor and goes to another metal piece that has a metal mouting plate that mounts to the wheel well. From there it goes to the firewall (and I assume the heater core). Would this be called a heater hose? Inlet, or outlet? Thanks guys.
Name for this part?
Roger, thanks for the help!
Edit: The hose that goes from the bleeder to the TB has a pinhole in it, what should I order here to get the right part? I'd rather get the whole assembly than just one part to crimp on.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
Originally posted by droptop zyeah, mine had a pinhole in about the same area, i figured that if just crimped on a new section, then there was a good chance that it would fail in another spot so i just ordered a whole one from the chevy dealer.
p/n 10261147 hose assembly.
Yeah, sounds like the best bet to me. Do you remember how much you paid for it? Thanks again!'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
Wow, I just looked at shbox's site and found it at gmpartsdirect.com for 85 bucks after shipping!! Thanks everyone.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
