GM parts direct shows two part numbers for the master cyl for a 1997 Trans AM anyone know what is the correct part?
Master cyl part # help
1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures HereTags: None
The parts list shows the 93-97 as 18019463 and the 98-02 as 18029857.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Thanks but both those part #s come back bad...I found these at kragen anythoughts ..recomendations
Master Cylinder
For vehicle: 1997 PONTIAC FIREBIRD TRANS AM V8 5.7 Liter FI (change)
3 parts found.
Description Availability * Price Buy
Cardone 102668
Reman.
Lifetime Limited Warranty
Find in a store
Ships in 1 day
Weight: 2.4 lbs.
$69.99
$20.00 core
Raybestos MC390214
Master Cylinder Assembly: Pg Plus; With Power Brakes
3 Month Limited Warranty
Ships in 3 days
Weight: 6 lbs.
$195.99
Bendix 13024
New; 1"
1 Year Replacement Warranty
Ships in 1 day
Weight: 2.4 lbs.
$188.991997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
18019463 was replaced by 18029857Originally posted by Jeff 95 Z28The parts list shows the 93-97 as 18019463 and the 98-02 as 18029857.
GM PART # 18029857
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $26.69
OUR PRICE: $15.22
The worst part is that is the part number for just the piston not the whole assembly. The parts list I have does not have a number the whole assembly.
Where are you located at? I have 2 in my carport right now.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
