Hey Joe, you gave me some advice awhile back about gettin a compression test done on my 97 ta because of a bad misfire that the dealership told me was internal. Turns out I took it to someplace else and the egr valve was stuck open. That seemed to take care of the really rough idle and sputtering under accleration after he put a new one on. Well my SES light is still on for I think a code maybe 0400?? Well anyway it is a random multiple misfire code. Here's the problem....When I come to a stop at a stop light or near a complete stop, the engine will give a couple jerks, shake a few times. It seems to do this after the car gets warmed up, but Does Not do it at every stop, most though. Also the Air conditioner will cut out a lil bit, loose power, and the Amp guage will fall below 13 for a sec. And I think even the oil pressure guage will bounce a little bit. What does this mean? Oh and by the way, did you ever dig up that SLP Cold Air Kit? Thanks
Jason
Jason
