Best LT1 starter replacement ?
  • Best LT1 starter replacement ?
    my starter is going out. i sometimes i just get a click but the starter dosen't turn. i'm sure its going bad. were can i get a good replacement? should i just get the oem starter from ac delco?
    thanks,
    ed
    Most LT1 starters (even AC-Delco) are rebuilt. You might consider an LT4 starter. It is a direct replacement, a little smaller and more powerful (plus it is new-not reman). GM PART # 10455709 ~$151 wholesale.
      or you could always go with a mini torque starter from summit or somewhere
        sup
        im not positive but almost sure that u can get a starter from a 99 yukon with a 350 vortec. it should be a direct bolt in. the starter is the GM mini starter with gear reduction.
        Im not sure what a lt4 starter looks like or if its gear reducted. But i looked into this when my starter gave me probs, it hasnt acted up since so i havnt changed it.. Let me know if it works.
        Doug
          gmpartsdirect.com wants $30 for shipping on the LT4 unit what a rip OFF !!!!
          anyone got a better place to get it??
          thanks,
          ed
            Could also go with a high-torque starter from Powermaster. My Jeep used to eat up starters every year, this one just keeps going. Sounds like a semi starting up too
            87 GN - its just a 6... Mods
              check ur battery terminal connections and the wires on the started, they might be corroaded or loose
                thanks,
                ed
                Sure.
                  GM parts direct changes a ridiculus shipping and handeling fee for each part in an order. I use Dal Salbaugh at Van Deere Olds in Akron Ohio for great prices and regular UPS rates for shipping. Call him at: 877-448-5451
                  The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
                    Originally posted by Rob B (shoebox)
                    [URL=http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason [/URL].
                    i've used both Dal and Jason and both are great. I primarily deal with Jason.... when the smoke clears, Jason is a hair cheaper as there are no additional handling fees added along with shipping.
                      A managed to kill two "stock" LT1 starters.... probably with header heat. About 4 years ago, I picked up a CVR Pro-Torque starter at JEG's for $150. Gear reduction, slightly lighter than stock, beefy Nippondenso motor, and a mounting system that allows it to be rotated into several different positions to clear headers and minimize heat exposure. I think it was a great deal.
                      I don't see the CVR brand in the JEG's catalog any more, but they appear to be selling the exact same starter, with their own brand on it, for $139. Part # 555-10001
                      The LT4 appears to be very popular, although I did see someone asking if it was OK that the starter did not fill the opening in the LT1 dust shield, which apparently is larger, because the LT4 is smaller. I don't know how the JEG's starter would look with the dust shield in place, because I don't have a stock tranny and there is no dust shield on the JW UltraBell.
