will there be a difference at all swapping my gears from 2:73 to 3:08? this summer i am going to buy a new carrier and go with 3:73.... but i have some 3:08 sittin around from my s-10
2:73 to 3:08
Originally posted by 96ws-6will there be a difference at all swapping my gears from 2:73 to 3:08? this summer i am going to buy a new carrier and go with 3:73.... but i have some 3:08 sittin around from my s-10
Sure, theres going to be a marginal difference, but I dont think I would do the job twice just so I could drive around with 3.08's for a few months. Youve got to buy the install kit twice and then youve got at least three to four hours in labor....wouldnt be worth it to me. I would wait to do the 3:73's.....96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
well i have the 3:08s already on the the carrier, basically just wanna swap out 3rd members... the pcm in my car is actually supposed to run 3:08s1996 Firebird Trans Am ws-6 a4
BBK headers
3in. Exaust with flow 80
Port and Polished Heads
58mill Throttle Body
Lowered an inch
2:73s... 3:42 goin in soon
2001 S-10
Air-Ride - SOLD
2003 S10
Lowered 6 inches
2005 HD sportster 1200 custom
Drag bars
Lowered 3 inches
What does "changing the whole 3rd member" mean? If you mean the whole housing, the s-10 housing is not the same........it wont just bolt in.
If you mean just swapping the carriers........You cant just slam another carrier in the f- body housing.....You still need to change the bearings on the carrier and the pinion, and also the races in the housing. Most importantly you need to reshim the pinion and the carrier for the proper backlash and pattern. You will also need a new crush collar and pinion nut to set the pre-load on the pinion. Swapping gears is technical job and can be screwed up pretty easily with just a slight wrong move.....96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
