C6 Z06 Drag Racing Videos from Beach Bend
Originally posted by ws6drbobWow.... Consistenly low 12's and a 11 second run from a bone stock car.
Wet track... 20 mph headwind... the highest trap for the C6 Z06 was 123.8
That yellow car was not a Z06 -- just a modified C6.Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
Those things ain't 500 HP at the crank like advertised.Originally posted by Jay 02 TA ws6Wet track... 20 mph headwind... the highest trap for the C6 Z06 was 123.8
was that performin norman running the 14's in the blue c6?
Awesome video jay97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Originally posted by Dave VinceIf the car weighs 3300 lbs with driver, and it ran 123.8 as was stated, the calculated hp is 470 at the flywheel. However all sorts of weather conditions affect track performance.
Where did you get that from???Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
It sounds like you are attempting to use the standard formula of HP = Weight * (Trap Speed / 234)3. This formula gives you a rough wheel horsepower estimate based on 1/4 mile trap speed, not flywheel. You would have to factor in drivetrain loss into the above equation to obtain flywheel HP.Originally posted by Dave VinceIf the car weighs 3300 lbs with driver, and it ran 123.8 as was stated, the calculated hp is 470 at the flywheel. However all sorts of weather conditions affect track performance.
No way a 3300lb car goes 123 MPH with only 470 flywheel HP. Not even close.
There are actually even "rumors" that GM has run the C6Z to a best of 128 MPH in the 1/4 in stock trim. Of course these are rumors, but given the recent pattern of GM released info spilled into credible forums, it does not seem all that far fetched given the nature of this car and motor.
Any way you slice it, this is going to be one bad mutha.
Originally posted by raroZ28was that performin norman running the 14's in the blue c6?
Oh SNAP!!!!!
ZING!!!!!!
Norm, step up to the plate, buddy.
The C6 Z06s also had a passenger during the runs.Originally posted by fastTAIt sounds like you are attempting to use the standard formula of HP = Weight * (Trap Speed / 234)3. This formula gives you a rough wheel horsepower estimate based on 1/4 mile trap speed, not flywheel. You would have to factor in drivetrain loss into the above equation to obtain flywheel HP.
Any way you slice it, this is going to be one bad mutha.Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
I've actually heard that a couple of times. For the life of me, I cannot remember the articles that I read it in, but I do remember in the articles is stated that GM ran the Z on its stock rubber, and ran a best of 11.5 @ 128 mph. I've come across those figures a couple times actually.Originally posted by fastTAThere are actually even "rumors" that GM has run the C6Z to a best of 128 MPH in the 1/4 in stock trim.
I'll try and dig up where I saw that at and post it.
Awesome vid
Come on...link not working for me...that is just wrong!!Silver 02 WS-6, 6 speed, Corsa cat-back, SLP lid, K&N filter, BMR STB, !CAGs, Lou's short stick, MSD wires, MTI "Hammer" cam, ASP underdrive pulley, Hooker LTs, Hooker ORY, Comp 918s, TR pushrods, UMI Sfcs, UMI LCAs, NGK TR55s, Hotchkis springs
Sounds like you need to crank up the boost on your Turbonator.Originally posted by Performin Norman
No, mine only runs 15.50s at 88 mph.
