agian . the trans . I changed out the vavle body on my 94 z 28 4l60e trans and did the wiring harness right . II went to start it and let it warm up ., Went to pull it out of the garage and it would not go into any gears .
I have the correct fluid and amount in there i have everything tight on the valve body . It worked when i was cold but not hot . What would cause this ..... The trans pump ?
Get it to a trans shop before you do more damage to whatever parts are good.
