I have anti-freeze dripping pretty badly from the weep hole on my water pump. does that mean that the pump is bad or just the seals.
If I have to replace the water pump, Do you guys recommend the electric water pump?
Thanks Cade
Thanks Cade
. A mechanical pump usually doesn't go out all at once, but gives you a warning - like yours is doing. Electrics are just more likely to die a sudden death. When I did the CSI, I plugged the weep hole so it wouldn't get the chance to tinkle on my opti. Electrics are good for 2500 hrs or so - for my car, that will be years. It's not a daily driver...
I wound up doing as head job with the water pump. I was able to fix the pump by resoldering the connections that came apart inside the pump. I cleaned the brushes up and off I went. I keep a real good eye on it now! I am now thinking about installing a mechanical arm that comes out and wacks me when the temp breaches 220
