What causes passenger side to be lower than Drivers side
  • What causes passenger side to be lower than Drivers side
    What causes passenger side to be lower than Drivers side on my 1995 Formula Lt1. I have already replaced the rear shocks and that did not help. Please reply. You can E-Mail me at husry@sowega.net
    Driver Weight. The car is best with one driver no passengers. So, the raised driver side equals out with a driver.
    This may be wrong, but I thought I heard that somewhere?
      Mine is lower on the p/s as well. I never thought anything of it. I hear about it with a lot of people I figured it's normal.
        I'm not positive on it either but I agree with you guys. The battery, ac components, spare tire and jack are located on the passenger side. I wonder if GM did this intentionally to even out the weight of having a driver?
          Yup. Could be better, but an effort nevertheless.
            I had the same problem on my 3rd Generation Camaro. I bought these rubber "coil spring boosters" and put only one on the side that was sagging. It leveled it out for less than 20 bucks.
            Darrin C
              Thanks for the input
              Thanks for the replies I am going to go ahead and replace the rear springs and if that does not solve the problem then I will use the coil spring insert and use a cheap fix. Thanks to all who replied.
