I am doing the front LS1 brake conversion and everything is going great.
However I have a question about the front brake lines. I am putting on the OE LS1 front brake hoses. I have already noticed that the inboard hose end wont fit into the mount due to the hex fitting. My question is should these LS1 hoses bolt directly on and work fine. They appear to be long enough but I havent put it on the ground yet. I have currentl bolted the LS1 hose exactly like the old LT1 came off. I also assume it will be normal for the hose fitting to be a little sloppy in the frame mount cause you cant slide the u shaped clip on. Again I just need the skinny on the brake hoses for this conversion.
Thanks
Thanks
