It's got 40,000 miles on it and it failed due to a low resolution signal failure. I opened it up and found that it was clean and that there was very little wear. The cap and rotor had minor corrosion and it could have continued to be used for many more miles. There didn't appear to be any signs of moisture intrusion either from wet roads or from a leaky water pump (which I've had already). The gasket was tight. What failed was the optical sensor module. I don't know if the LED or detector failed. I wonder if they're ever going to sell this module as a separate part so that you don't have to buy the whole distributor.
Warren
96 T/A,WS6,M6
79 T/A,WS6,A3,403
72 442,W30,A3
Warren
96 T/A,WS6,M6
79 T/A,WS6,A3,403
72 442,W30,A3
