I'm trying to fix a Z for a frind of mine. His A/C compressor took a crap and the C.E. light was on so he took it to the dealer. They told him he needed a new compressor and 2 new cats for a total of.....$3,000!
I thought surely we could fix it much cheaper than that. I priced the compressor at $322 plus freon. No big deal. Today I finally drove the car and, other than a little miss, it seems ok. I don't think the convertors are bad but is there a way to tell for sure? I also pulled the codes and it showed a 300 and a 420. I just read a post about all things electrical related that could cause the 300 but with the miss I was thinking a good tune-up would be the place to start. Now, the 400. Would O2's cause this code or could it in fact be the convertors? The few times I've driven a car with bad cats it acted like it was plugged up and it smelled bad. This car shows no signs of either. Since the car has 130,000 miles I figured the O2's are probably the culprit but I wanted to get some expert advice since I'm going to be charging him labor and I don't want to just start throwing parts at it and not getting it fixed.
My plan for now is to replace the A/C compressor, expansion valve, orifice tube, dryer and filter and replace the freon. Also add a new belt. Then the O2's and disconnect the PCM wire to reset the light and see if that solves the problem. I will also tell him a good tune-up (plugs, wires) wouldn't hurt either. Should I replace the Opti as well?
Please give any advice you can because I want to be fair but also make a little side money as well. Thanks, Mike
I thought surely we could fix it much cheaper than that. I priced the compressor at $322 plus freon. No big deal. Today I finally drove the car and, other than a little miss, it seems ok. I don't think the convertors are bad but is there a way to tell for sure? I also pulled the codes and it showed a 300 and a 420. I just read a post about all things electrical related that could cause the 300 but with the miss I was thinking a good tune-up would be the place to start. Now, the 400. Would O2's cause this code or could it in fact be the convertors? The few times I've driven a car with bad cats it acted like it was plugged up and it smelled bad. This car shows no signs of either. Since the car has 130,000 miles I figured the O2's are probably the culprit but I wanted to get some expert advice since I'm going to be charging him labor and I don't want to just start throwing parts at it and not getting it fixed. My plan for now is to replace the A/C compressor, expansion valve, orifice tube, dryer and filter and replace the freon. Also add a new belt. Then the O2's and disconnect the PCM wire to reset the light and see if that solves the problem. I will also tell him a good tune-up (plugs, wires) wouldn't hurt either. Should I replace the Opti as well?
and boy does it look good now. I thought the wheels were silver, not brake dust brown. LOL Anyway, it didn't seem to miss on the way there but the car had time to cool down and the wash is about a 2 minute drive from my house. Wouldn't it still be operating in closed loop function? Today when I went to the parts store it had plenty of time to warm up and that's when I noticed the miss. That should've been open loop, correct? Does this info make sense or help narrow down the miss problem? Thanks for the input and please keep it coming.
