I changed my water pump the other night. It was running fine, but leaked. I noticed it because it was dripping but the opti did not appear to be wet yet and like I said it was running fine.
While I had the water pump off I noticed the front of the motor was a little dirty. I removed the balancer and the opti to clean it all up.
While reassembling it I lost the order of the plug wires on the passenger side and had to tug on them and look up with a flashlight to verify I had them on correctly.
I put it all back together and started it. I allowed it to idle for about 10 minutes looking for leaks. It was raining so I did not test drive it, but it seemed OK at idle. Maybe it had a slight miss, I'm not sure anymore. There was no indication of the cat getting hot, but it only idled.
I got in it to drive it today and it has a slight miss at idle. It is drivable, but not very powerful and definitely misses alot through the RPM band. The cat is glowing red and smelling terrible. I drove it a total of 3 miles like this before shutting it down.
I'm thinking that maybe I hurt one of the plug wires when messing around with them and it is missing because of that? The miss allows unburned gas to get into the cat and heat it up? Should I start by replacing the plug wires? I have no idea how old they are, but they do appear to have been changed at some time.
Any advice? Thoughts?
