B&M Transmission Coolers 24000 GVW, 11" x 6" x 1-1/2"
This is the smallest size and lightest weight cooler relative to cooling capacity you can buy! B&M's Supercooler low pressure drop coolers reduce the risk of lube system failure. A controlled amount of automatic transmission fluid (ATF) is allowed to bypass the stacked plate core, passing through a self-regulating orifice, which monitors resistance to flow. Controlled by viscosity, the thicker ATF is returned directly to lube through two open bypass passages positioned in the stacked plate core. As operating temperatures increase, more of the ATF flow is directed through the core. The result is highly efficient cooling technology that combines improved protection against lube system failure with the required levels of optimal heat transfer. 59-70264 B&M Supercooler Transmission Cooler, 24000 GVW, 11" x 6" x 1-1/2" [img] http://www.stealthperf.com/store/ima...MM-70266_m.jpg[/img]
B&M Deep Transmission Pans [ 4L60E Transmissions ]
B&M Deep Transmission Pans B&M Cast Aluminum Deep Transmission Pan for 4L60E has an additional 3 qts. capacity over the stock pan to keep your transmission running cooler. Other features are: · Increasing cooling ability · No modification to the dipstick is needed · Fluid pickup extension and gasket provided · B&M Deep Pans feature built-in drain plugs 59-70260 B&M Deep Transmission Pan for 4L60E Transmissions (replaces part number 59-70294)
[img] http://www.stealthperf.com/store/ima...s/transpan.gif[/img]
Super Combo Deal B&M Transmission Coolers 24000 GVW, 11" x 6" x 1-1/2" / B&M Deep Transmission Pans [ 4L60E Transmissions $ 199.95 + shipping
keep it kool
